scraping sound
Yeah when it's freezing out...I think it's the caliper sticking because it only happens for a little bit then if I drive away fast or pump by brakes it'll go away.
no its no hum....its a loud screaching. like the heat shield. i go faster...it makes a faster scrape....then eventually goes away.
I had a piece of tar (just a pebble) that got stuck between the heat shield and the rotor, it made a TERRIBLE noise! It was very very loud. I just got under the car and used a screw driver to bend it out enough for it to fall out and won't happen again.
im going to remove my wheels to take care of a few things so ill bend it out then just in case. thanks
+1
My driveway is rock and somehow one ended up wedged between the dust shield and the rotor. Made a horrible sound.
occasionally i get a brake scraping sound. cant tell if its the shield or caliper? anybody have the same problem ever?
How new is the car? for about the first 1000 miles or so, I had a scraping sound from my brakes and it was just the brakes breaking in. its nothing major.
