Wheel specs are:
18 x 8
5 x 114.3
51mm Offset
Make sure to check the hub bore, you may need hub centric rings.
Could you elaborate? I'm not too knowledged about wheel terms - as you can see
I thought the stock wheels are 18 x 7? So that makes this 1" wider...not .5".
Wheel specs are:
18 x 8
5 x 114.3
51mm Offset
Wheel specs are:
18 x 8
5 x 114.3
51mm Offset
