Good Day
I have a 08 MS3
Has anyone had this problem, at 20K miles I noticed a long piece of plastic hanging down with the back lip of the rubber gasket that seals to the intercooler, the rubber strip was hanging about 1".
Took it to dealear said they couldn't replace just the plastic locator, they would need to replace the entire ram air assembly. ($500+) under warranty.
The service manager said they had never seen anything like it.
They replaced it and gave me a loaner while they did.
I just changeged my oil at 30K and to my surprise the rubber seal was hanging down again.
I can only think thet the rough roads under acceleration here in WI have caused a lot of wheel hop several times, I am thingking the motor is moving around so much that the solidly affixed scoop resting on TMIC with motor moving is breaking the plastic locator plate.
I let them know at the dealership and they are ordering another scoop assembly and they still say they have no idea what is causing the breakage.
Has anyone eles had this problem and if so do you have a better fix than a $500 unit when it is out of warrenty in a couple months?
Thank You
I have a 08 MS3
Thank You
