Need some help
neysha_eddie
MSP
so i had my msp for over a year now and since i had it i notice the block was dirty like oil dry up on the block i seen everyone else pics and they look clean my i ask whats the cost of this and how can i get rid of it.... I also randomly started hearing this horrible sound coming from the engine bay mostly when i turn the car on and is at idle once i hit the gas it goes away any idea the help will be appriciated.
youll have to be more specific about what this noise is...
As for the dirty block, it comes from the valve cover gasket being dried out/old and allowing some oil to seep out over time.
A good APC and a scrubbing with various brushes will get rid of it.
well the way i can explain is either metal rubbing together or if not mistaken timing belt needs to be replace is hard to explain the noise all i know the only way i can get rid of it is by hitting the gas
You wouldn't happen to have the Medieval Alternator Pulley on your car, would you? If so that may be the reason for the metal sound, mine failed on me and the lip came off of the inside of the pulley, rubbed around and gave a similar sound. If it's not that, then maybe the belt.
you know what let me check that out thanks for the advice
Some pics.. can't see much, but the inside lip of the pulley isn't there, since it snapped off. It will actually be still in there since it is an O shape, but will just be dangling around and causing a metal/chain (like a chain dog leash on pavement) sound.
