interesting idea. if you figure it out, you gonna post a how-to?
I'm pretty sure I hooked it up right. The only thing that bothers me is which wire to connect the knocklite signal wire too. There's two wires connected to the ecu. Pin 57(yellow/blue wire) and pin 59(red wire). Pin 57 connects to the factory knock sensor red wire and pin 59 connects to the factory knock sensors black wire. I opted to connect the knocklite sensor wire to pin 57 since it connected to the factory knock sensor red wire. My reasonig for that is because if you use a aftermarket kncok sensor you connect the knocklite sensor wire to positive according to the installation instructions. The knocklite rpm signal you get from pin 48(lavender wire). So far the shift lite portion of the knocklite works fine. I've callinrated the knocklite and I guess I'm not getting any knock but that all depends if I tapped the right pin(57or59). I put a tap on pin 59 but haven't tried it yet. Also not going to try and up the booost to try and purposly cause knock. Hmmm
