I am getting some oil in my intake through the crank->intake breather hose. I am FAIRLY certain this has been going on awhile. When I would remove my stock TMIC back in the day there would be a little bit of oil on the hotside... once I found oil in my intake I figured this must be where it was coming from all along. Anyways, its a good bit of oil. Keep in mind I do have something like 25k+ miles on this intake, so this is all that has built up over that time. It's still a lot.
Some people thought maybe the stock PCV valve was clogged or something and forcing stuff up through the valve cover and through the breather. I recently installed an Oil catch can though to the PCV system and it fills up fairly quickly with lots of nasty stuff... so it seems to be working as far as I can tell. Is it even possible to access and remove the PCV valve without taking off the valve cover? if I was going to check it out.
I just ordered another catch can to hook up to the intake because regardless I don't want this crap getting into there. But I need to find the root of the problem. Just looking for help, advice, wisdom, anything. I really don't really have that much experience with cars in general. This is the first car I've ever really cared or known much about. Thanks.
