30,000 Miles
* If necessary, inspect, repair, clean, adjust or replace Cooling system , Fuel lines and hoses *2 , Brake lines, hoses and connections , Disc brakes , Steering operation and linkages , Front and rear suspension, ball joints and wheel bearing axial play , Driveshaft dust boots
* Lubricate All locks and hinges
* Replace Engine oil , Engine oil filter
* Tighten Bolts and nuts on chassis and body
I have never been a fan of dealer performed services.. Either cross out s*** thats not needed, (i.e. all of it). If my bolts in my chassis and body need to be tightened.. I will have to say that's pretty bad.. but they dont so its just a scam.
600 dollars for a lookover and lubricate the locks is just crazy. I bet if they actually found something that needed to be replaced it would be on top of the 600 bucks.
Just do all that s*** either at a decent mechanic or do it yourself and keep receipts/logs of it.
