Greased the bushings on my AXR clunk fix. That fixed the squeak. However, I went ahead and ordered the Energy Suspension 19 mm bushings. I've been reading that they are a better fit and after they break in, they still fit snug.
how do you go about lubricating the bushings up front? when i hit a speed bump it goes crazy and the squeak is really loud. what type of lubricant do you use?
white lithium grease...picked some up at advanced auto the other day...remove the brackets that hold the bushings in place, remove the bushings...cover the inside with grease and re-install...same as the rear. just look under there and you'll see them...jack/jack stands will come in handy.
White lithium grease, like he said ^^
To get at the fronts...I have noooo clue. I've heard it's a b**** to get at them. I've looked under there and it looks like a crossmember has to come off.
Topher, it was that easy for you? They look like a b**** to get to, especially the passenger side.
new mods...
2000 626 motor looks like less than 50k but they said it had around 75k --$600 shipped
2000 626 intake mani --came with motor
new air filter --$25
egr bloack off plate -- $13
welded lsd---gettin it welded tmrw
spec stage 2+--$450
midieval llc motor mounts all 4 $230
joeP MBC $40
i have yet to install everything but will hopefully get to this weekend and will post wat i come to find.
yo anybody have any kartboy or corksport hangers they wanna get rid of? my exhaust is rattling like crazy
i have an aperr1 j/mid and gerddy sp2 catback.
That must be quiet, I always thought the Greddy is way to quiet for my tastes. But a lot of people like how deep it is when you get on it and then sounds factory when cruise.
i love the way it sounds. i used to have a 2.5 fart can on my mirage for years, loud as hell. if i cant find a set of hangers on here ill just get the corksport ones
you could either get the 626 egr tube or go the home depot route... im going to block mine off too.. i already have the plate just waiting to install it someday... but for now i just took the tube and bent it in a couple places to seal it off sorta... and why? because my manifold doesn't have the hook up for the egr tube
i got the plate for the intake mani and i got this thing for the exhaust mani thats like a nut with a cap on the end of it. all you do is screw it on the exhaust mani and capped off and sealed. perfect...lol
