GOT THE STEEDSPEED ON!!!!
YEEEHAW!!!!!
Seriously, it has more power down low, and it seems like it spools up a good bit faster. It was raining, but it spun tires in 4th, and it's never done that in the rain. It would usually spin 1st, and 2nd, but not 3rd, and 4th.
Now I gotta get the new meth controller set up, and I can do some high boost pulls.
Also, I'll post my impressions after I drive it when it's dry out.
what other mods do you have?
About the same as you minus the turbo upgrade, but add methanol.
Stock boost?
YEEEHAW!!!!!
Really eh? I've had mine on for months at 7-7.5psi and haven't felt much...but I wasn't expecting anything at that boost level. It just feels healthier sorta and the exhaust note on mine sounds a little different than before.
Hi there, people i need some help here, im trying to install my new EBC and i need RPM signal, from where and how can i get it? any pictures, diagrams etc ?
	Thanks John.
Bingo!He might notice more of a difference depending on the shape of his stock exhaust mani. Mine had a crack it in. So I imagine that was causing some issues.
purple/white wire at either the ECU or the diagnostics box in the eingine bay (right behind the strut tower behind where the battery ground is)
You can see here where I spliced a green wire into it for my tach...
Here is the box, it slides right up off the bracket...
Man Thank you very much, You just don't know how much i needed that signal and how hard i looked up over the web to basically find just nothing. Anything you might need i'm here to help Count on it... I'll post pictures of the new toy I' am installing..
	Finally after the help of few good friends in here i found the RPM signal and my new toy is installed and working like a champ.. let me know what you guys think..
Greddy Profec E-01 & Greddy Remote Switch Hi/Lo Boost.
This Unit from Greddy is so damn awesome, I just need to deeply read the instruction to learn all of the features it has.
