Just got Rota 17x8 GunMetallic G-Force wheels mounted with Bridgestone Potenza G019 Grid 235/45-17 all-season tires. So sweet.
Unfortunately, I think I might have a wheel balance problem. There's still a wheel weight on the inside of each wheel but my car has a strange shimmy above about 50 mph ever since I put the wheels on about a month ago. I haven't hit any potholes since I got them, so I don't think there's any wheel deformation. I feel the shimmy accelerating, coasting, or braking but I notice it the most while cruising on the highway at 65-70 mph.
The weights are the adhesive-type placed on the inside of the wheels.
On two of my wheels, the weights are on the flat part of the inside of the wheel and closest to the hub-side edge of the wheel. Not sure if locating them in the middle of the width of the wheel makes a diff or not, but they're on the inner flat surface nearest the hub.
On the other two wheels, the weights are placed on the inside lip of the wheel that is just behind the "spokes", so you can see them easily from the outside looking in at the wheel. What's more is that this lip that goes from the back-side of the spokes into the flat inner side of the wheel is not "flat" relative to a perpendicular from the center of the wheel outwards to the surface of the tire. It kinda curves from the spokes to the flat inside of the wheel.
Know what I mean? Not sure if that matters or not.
Does anyone have wheel balancing experience?
Could this be the cause or am I likely barking up the wrong tree?
Maybe it doesn't cost much just to have them all rebalanced, but I hate having my new wheels handled any more than I have to.
So if the cause might be something else, Id like to hear it.
Car has 4K miles on it.
thanks,
Pete
thanks,
Pete
