well, if your TPMS light is coming on every time it drops below 50F, it probably means that you need to add more air, because your tire pressure takes a severe hit as it gets cold out. i believe the stock threshold for the TPMS is 27psi, so you're going to need a lot more air in your tires.
Everytime this happens, the front pressure is around 30 psi and the rear is around 29 psi. I understand that the pressure will drop when the temprature does. When I checked my tire pressure yesterday morning (55-60degrees) the pressure was perfectly fine. As stated before, there are leaks in my tires and the TPMS checks out fine. I just can't believe that this worthless system is this sensitive.
If you have your pressure set at least 35 PSI, low temps are not going to drop it 8 PSI. Your tires are too low to begin with.
I set my tires at 34psi and the rear at 32psi. I really don't see a need for the TPMS.
