they are legit Mazdaspeed springs, they should fit.
Although, I do recall somewhere someone saying you need new spring perches and abuncha other stuff to run the Mazdaspeed springs
dude I keep telling you its easier, cheaper, faster to just get a built auto then to convert over. A buitl trans that will hold 275whp will be cheaper then a swap more then likely.
Your biggest issue will be the wiring differences between the dash harnesses of the atx and mtx.
Well thats a start...
Did you go turbo?
I know the feeling!I dropped her off at a shop today. I'm sad and nervous at the same time...![]()
No, I blew 3rd gear on my AT lol.
I wish I had teh boost though...
I dropped my car off as well, its sad to go out to my garage and see it empty.![]()
No, its ok. Its being fixed... gonna cost a ton but its gonna be fixed.
If you're running the stock P5 ECU is will make you run very lean. The stock supermap pulls fuel because the base MSP maps are very rich.I wonder what's going to happen when I load the SSAFC Supermap?
Where does he have the "switch" set for the AFC to go from closed to open loop? On the supermap I believe it's 1.1 psi or something similar. This way, with the MSP ECU (or even the P5 ECU) the car drives just the same in vacuum. If you want to keep the P5 ECU I'd set the "over pressure" setting to like 1.1 psi as with the supermap. The only difference is that here you will have to add fuel (values greater than 10) rather than pull fuel (less than 10). Just remember you can't run too much boost with the P5 ECU because it will require you to try to add too much fuel (increasing the MAF signal voltage to the ECU) and will cause the ECU to fuel cut and throw the "MAF voltage too high" CEL.darn. What should I do? I'm running the stock P5 ecu with a n/a map from jamesk. If I remember correctly there are all 10s when it hits 0psi in that map.
if u get a good map to run with the stock mp5 ecu let me know thats what im going to be running in my car.sounds complicated. I'm going to try and pm jamesk for a turbo map. I think he's using the stock p5 edu and ssafc
I mean I could have kept driving it, but tell me if you would... VIDEO
Figured I would take it into the shop while it still drove instead of ending up having it towed to a shop later this week![]()
