I put in this shifter about 2 months ago:
http://cgi.ebay.com/ebaymotors/_Car...543|39:1|65:12|240:1318&_trksid=p4506.c0.m245
First off, they DO NOT fit. At least not without modification. I had to grind down some material for it drop in. If you don't have a Dremel or a grinder you will be stuck.
Now today, I was driving along, and the shifter dropped into the boot ! I was able to get home by lifting the shifter and moving through the gears. Turns out, the pivot ball, (which is a separate piece), popped a small retaining ring and let loose.
Needless to say, you get what you pay for. Therefore, I just ordered a new B&M shifter from Protege Garage.
