When you install the MBC, take the extra time to install it right. I found the best way to install is to remove the lines from the factory boost control solenoid (one goes to the intake, the other to the top nipple on the wastegate actuator), cap off the nipple on the intake, cap off the nipples on the factory solenoid, cap off the top nipple on the wastegate actuator, remove the short hose between the bottom nipple of the wastegate actuator and the compressor housing of the turbo, cap off the larger nipple on the compressor housing, run a vacuum line from the bottom nipple of the actuator to the side of the MBC that the arrow is pointing to (arrow points to the wastegate actuator on mine...that's what it says), then run another vacuum line from the other nipple on the MBC and splice into the vacuum line that connects to the bypass valve. That way seems to have the most consistent boost pattern.
