103 maps
103 maps not released yet but you can go to the cobb forum page
I just got on as a beta tester for new maps.
They are still looking for beta testers for 103 maps.
Go and sign up and they will give you all the info and send you a map.
One thing though, you must have a Dashhawk for Data logging.
ok to not be an ass- its a map file you load onto the ECU.... youre loading a pre made tune into the ecu
the v103 maps, absolutely better than the v102 maps, i still have to dyno with it but the car shows much more power in the middle range. props to christian on these maps.
The 103f was still behind the stock map (for me car) in the midrange. The dyno shows a stock ECU vs a 103f 2+ SRi FMIC map. Both pulls were on a fresh flash.
I think the 103i and 103j (which I have tested but not put on the dyno) push the tune above the stock tune. If Cobb continues in the same direction all the way to release, these will finally be tunes I think anybody will be happy with. Still think street tuner is what will really make the AP worth it though.
Erich what are your mods im curious. Also we can see now it holds boost at the higher RPM as well as hp but nothing for the AFR.
I'm currently running the S2_FMIC_CA_91Oct_v103k Maps and I can tell you my car has never pulled like it does now. I have a dyno day on the 4th and I'm really anxious to see the results.
I second this! I rode in his car and felt the difference, especially with (Bravnik, udontknowjack and me). This map is pretty damn good.
