7th Generation Mazda navigation system questions
2025 CX-5 Turbo Premium
As I've mentioned last week, I've got a 2025 Mazda with the 7th generation infotainment and I am trying to get accustomed to it. I've got few questions, maybe you have some answers:
1. I bought an SD card from e-bay, managed to update the map to the latest release, September 2025. However, it did not let me do a back-up and got a message saying that the card was corrupted. Yet I was able to use the navigation today with no issues, none noticed, anyway. As soon as I received the card, I tested it, drove around, everything looked good to me. Then I spent almost two hours with the update. After the update was complete I re-inserted the card into the nav port, the map popped up, everything looked good. Checked the map version and it says 25Q1011500. I wonder if this the latest map version and whether this card is it really corrupted or some other people got similar message although, like I said, the card work just fine, no errors while using the navigation, the update succeeded but no back-up? So this is one question, what's the latest map version.
2. And now the second one. Please look at the pictures: How can I get rid of the black info table on the right side of the screen? On the 6th generation it was easy to hide it but on this generation I can't seem to figure out how to hide it. I don't need to know where the next gas station is at all times. I'd rather have the whole screen showing me a clean map.
I figured the answer to question No. 2. Under Navigation settings menu, go to Guidance settings and uncheck Highway Exit Information.
How did you manage to update the map? I would appreciate it.
I used Mazda toolbox called MapUpdateGlobalAdv. Update was successful but no back-up. The process lasts a good hour, I’d say.
After today's driving and playing more with the navigation, here's another observation.
I've noticed that the system does not show the number of the freeway exit on the main map page. You get the arrow and the distance to the exit but no exit number. The only way I can see the exit number is if I set the "Junction view" active. You can see the number in the small Junction View window. Really hard to see it at night. In the 6th generation navigation system, the exit number was displayed. Is there any solution for this problem in the new navigation system or I just have to shut up and deal with it? 😆
Funfact about the built-in maps. Compared to Waze or Google maps, it's kinda garbage.
Don't worry about ever updating the Mazda maps again, just stick to Android Auto or CarPlay (depending on which phone you have), and use that for navigation.
I actually like it. I find it better looking than the 6th, faster. I use the native system as the main source of navigation, google maps is the back-up.
Speaking about the freeway exit number, I've noticed that if you enable the audio guidance you DO GET the exit number AUDIO , in conjunction with the visual queue in the "Junction view" that pops up on the right side of the screen. IF you pay attention to the audio! 😆 If audio guidance is disabled, only Junction view will show it.
I updated the Euro maps version but process slow and painful. On Windows 10 PC, though Windows instantly saw card, update s/ware didn't- removed SD, tried again- no joy. On a WINDOWS 11 PC, s/ware saw it. Around 4 hrs to do back up, and screen pop up says b/up successful.
D/loading new map files left PC to it; later had error message, and to restart. :unsure:Fortunately it hadn't lost new files previously d/loaded. Shouldn't take so many hours! At end it then says b/up wasn't completed. Go figure.
My update of the European maps went well on a Windows 10 PC. It took a long time, but it finally succeeded.
Does anyone know where the map BACK UP is stored. I assumed on your PC's drive, but that surely would allow BACK UP to be accomplished much quicker than 4 hrs I suffered! Other possible places presumably are on SD CARD, or in the cloud?
On your computer. When you updated the SD card, the first thing that happened was the creation of the back-up file.
my card is not being recognized by the update software. Not sure if there is a way past that part
Make sure that you are using the appropriate Mazda Tool Box for your car. If that's not the case, most likely you have an after market SD card which was already paired to another VIN number. When you buy an SD card from Amazon or e-bay or other places, make sure that the SD card has not already been paired.
Does your computer recognise the card when plugged in to appropriate slot?
Warez09, did you figure out the problem? I have the same problem with my 2025 Signature. The first time I tried the map update Win11 said there was a SD card problem.
No I have not, I forgot to mention that I had updated the infotainment to the latest firmware right before the issues started so my assumption is that Mazda had closed the loophole here. Maybe buying the newer versions of the map would solve this problem
