Hi people i need quite help here.. this is my issue, My car overheats almost every time I go hard to it, my overheat is the needle goes up not near H spot, but like 3/4 and then slowly goes back down to normal, and stays there if i drive the car normal, I'm on my 2nd OEM Coolant tank, they get ****** up where they attaches in the middle and start leaking Coolant, I notice the coolant bouncing bouncing inside the can. I don't have Coolant on my oil or oil in my coolant, what do you guys think might me the damn problem. I'm tired of buying Coolant cases because every time gets hot the coolants spills all over the place and i have to refill the rad and coolant can every time. You guys thinks is the Thermostat ? do you guys have any part Numbers for them, any specs of the degrees of it, any pictures ? I'm trying to find them here in Spain but what a Pain in the ass needed to buy everything from US, not to mention i have to wait a damn week to get stuff i need....
any help will be highly appreciated..
I also Downgrade from a Mazdaspeed 1.3 bar Rad Cap, to a OEM 1.1 Bar Rad Cap to see if that was the problem, but negative. there is nothing worst than having a damn car that Overheats...
