Mazda Protege Owner Photos
You ever seen the bc2 sides off the car? NOTHING like the stock sides. The stock sides curve with the body of the car, the bc2 sides don't, they just drop straight down...
These are actually the ones I use to have on my car, anyways, you see how there is a small lip across the top? Well the way they were on my car was with 2 screws on both ends in the fender wells and several screws through that lip across the top into the door jams.
These are actually the ones I used to have on my car, anyways, you see how there is a small lip across the top? Well the way they were on my car was with 2 screws on both ends in the fender wells and several screws through that lip across the top into the door jams.
ouch....
Screws, yuck!! Mine are glued along the top, and one screw at the back, one at the front. Had to get the tops shaved on the inside so the doors didn't rub them. Also, I had 3 brackets made to secure it underneath, to the frame. They are hard as a rock, no movement in the skirts at all.
I had an idiot install my skirts, thats why it was mounted in such a ****** up way.
just changed the oil and tranny fluid :D i feels like a load off, been saying im going to for like 3 weeks.
but my cel is still on :[ my cilonide D is in the "stuck on" position (dunno) not sure how to fix
