does that how-to link work yet? I really want to do this because there was 3 626 at the junkyard with the IM intact... the closest one being the 97 626... so if you can get that link or even a short how to on this thread would be nice...
how much are IM ideally at junkyards??
You can adapt our injectors to use the older style 626 mani's fuel rail using with a spacer. You will need the fuel rail from that mani since ours does not have the same mounting points.
Its doable, I run one
