Just registered, and my first post here...
I've read through a lot of the pages in this here thread, and after much enlightenment, I'm going to try this myself. Like most of you, I have a 2001 Protege ES with some issues. Mine specifically runs rough when shifting into higher gears/idle issues etc. My CEL actually flashes off and on when I'm on the hwy and I get a major loss of power at that point. It's like one of my cylinders actually stops working and it compensates the other 3 and runs semi-smooth until it resets itself. The CEL will actually go off after a while, but only for a day at most. It's had this problem for a few months now, and my Mazda has 154k on it! I know, pretty high. Me and my dad actually tried a few diff things on it last winter, like spark plugs etc. If I rememer right, I was getting the code 302. I think it was a misfire code. So, I'll post the end result as I'm gonna try this on Sat. If you have any words of wisdom please let me know!
P0302 Code - Cylinder #2 Misfire
Technical Description
Cylinder #2 Misfire Detected
What does that mean?
A P0302 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #2.
Symptoms
Symptoms may include:
* the engine may be harder to start
* the engine may stumble / stumble, and/or hesitate
* other symptoms may also be present
Causes
A code P0302 may mean that one or more of the following has happened:
* Faulty spark plug or wire
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Running out of fuel
* Poor compression
* Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
I personally would change the coils/wires (at 154k, its a good idea if it has not been done in a while), see if that fixes ur problem. If it continues then just replace the injector on the second cylinder. I have some spare injectors laying around, let me know if u need one. Pretty sure they are the same for 01-03 proteges.
