a mpg drop from installing a lightweight flywheel?
how much of a mpg drop we talkin here?
I'd like some more explaination on this theory. Are you assuming that you keep the car in gear while braking? I find it hard to believe that you would use more gas with you car idling than running a higher rpm under engine braking.
well obviously if your boosted your WILL get worse gas mileage but if you dont change your driving habits between summer and winter the difference you see is the different blends of fuel for the seasons, yes they change. also iv personally noticed 3-4 mpg drop when using 10-15% ethonol fuel versus straight gas. iv also noticed and extreme difference in MPG when using 87 vs 93. on 93 i get 30-33mpg last i remembered 87 23-26MPG. im always checking my MPG every fill just to check for craziness. my car 01 mp3 not turboed yet full exhaust header 2.5 no cat, short ram intake, light weight flywheel. also should mention i noticed a bit of a drop with the flywheel install as there was less stored energy maintaining speed. just a little food for thought.
z
The MP3 ECU is tuned for advanced ignition timing. This requires the use of a higher octane fuel (doesn't ignite as easily). If you use a lower octane fuel, there is more potential for pre-detonation (knock). The computer in our cars picks this up very easily and quickly and will retard the timing so that the combustion chamber can cool down. In the process, you lose power and need to use more fuel to perform the same work from the engine.
Why is honda making such a big deal about the new Fit getting 33 MPG on the hwy? I just recorded 34.5 mpg on a 188 mile trip. All interstate driving, about half of it at 80 mph average (we were in a hurry to get there) and the other half at about 65-70 mph. This was also all done at an altitude of 5200-7800 feet above sea level! I couldn't imagine what I might get at sea level on flat roads.
My car is 8 years old, handles like a dream, is a blast to drive and looks great. Not to mention I can fit 4 adults comfortably. Where is the advancement in technology?
wow!! you guys make me so freaking jealous!! i'm constantly getting 23-24 pure city, the only thing that i have changed about the car is 18" rims. everything else is stock. WTF!!! what am i doing wrong here. i'm using 89oct
well that makes me feel a little better lol....
but all you guys talking about how your going like 85 and stuff... are your rpms at like 4000+??
