Beautiful rims?
Not bad @ $165 (each) but they aren't exactly light 22lbs. That's only like 2lbs less than the stockers. Personally I wouldn't go aftermarket unless the wheels are at least 18lbs or less. Those rims look alright though.
I agree, save up some more money and get some lighter wheels. If you got 18lb wheels you would shave 24lbs. total off the car and that is huge. Since its from the wheels it would help braking and handling too.
I like'm. Some people are looks over function. So what if they're only 2lb less than stock? Going light and strong is going to be pricey. At least double the cost. Depending on your driving habits, the only difference you may feel between an 18lb wheel and a 24lb wheel is in your wallet.
good choice. as long as you are close to original wt. you will not have any downside. rule of thumb; every 100lbs. lost= one tenth of a second off 1/4 mile. (1000 lbs.= 1 second less)
Too heavy. I will one day go to 17" and 16 lbs. I like the stock rims on my CB Speed, and will only change them out to get much lighter rims.
Agreed! I am looking for some new black wheels and amazed how expensive lighter weight wheels cost.
These are sharp, but keep in mind that these cars give off terrible brake dust. Will these be easy to clean?
