squeeking
Mazdaspeed3
my front end squeeks over thing like expansion joints small frost heaves etc... its the two front wheels....anything to worry about and is it an easy fix maybe? thanks
little help. **** it....ill just bring the damn thing to the dealer so they can tell me nothings wrong with it and i can waste 5465794657946579024 dollars in gas bringing it back and forth. lol.
i've been having the same problem i think. Its like a tiny squeak but annoying as hell. I only hear it with the windows down pretty much. The dealer wouldnt fix it because they said it must have happened from my oversized tires and rims. I think i've determined its coming from the brakes though. at first i thought it was the suspension.
ME TOO i've been meaning to bring it in. Actually its more of a squeek / cling noise... thought endlinks loose but they look good...
its every time i drive so its nothing that i couldnt recreate but my dealer is a little less than an hour away and with gas the way it is thats far enough of a drive to shun me away from going for now. i dont think its anything huge just like you said annoying. im glad....sort of....that theres more than just me so i know its a universal problem that maybe if one of us gets it we can all be rest assured.
ah ur in MA ... what dealer? The dealer I normally use is also an hour away but I really like using them...if its the same dealer I use and they could resolve the problem it'd be worth your drive...
i use the dealer in shrewsbury. im not sure the exact name of it but i know they are located right at the junction of rt 9 and 20 near the x-mas tree shop and sears outlet. theyve been awesome so far and the tech there is one of the number 1 techs for speeds in the country. same one you go to?
Sentry West ... I use 'em. I use the local spot for little things but when I want something taken care of that requires some work they ... well hopefully I'll be in next week and get back to ya. Its tough because I need to line up a rental each time.
yea sentry west. seriously good techs there. they are def thorough in what they do. i live in charlton right off of 20 so its about a 45 min drive for me but its far enough where i can only do a drop off too. ill prob set something up also within the next few weeks so whoever gets in and out first will be able to supply the solution to the other.
I have a clicking noise coming from my front driver side i took it to the dealer and they told me it was the brake pad clicking when stopping and going because the pad is like 1 millimeter or so to small so the pad shifts from front to back, when stopping and going. i don't know, is anyone else having this problem? also i am having a very quiet squeaking noise when i go over a bump.
Thats what they told me! They were so ****** incorrect cuz it was my mount.
This is all you gotta say " so you mean if i drive one of your cars its going to do the same thing?" and then drive it :D
it was the mount?? Mine is over expansion joints not necessarily hard. Either way ... I still haven't brought mine in because I've been taking the train to work
Mine's been doing the same, like a squeeky clicky noise from the front end at low speeds over semi-rough roads, I will be taking it to the dealer next week.
I know it's no help but I checked my car out before taking it to the dealer and it turns out my cat back exhaust was just a little loose hence squeaky clanky sound, sorry bout that.
I'm told I need my front mounts and struts replaced. Not sure if this is one or both and if its the same failure the car and driver report had. (I think it was car and driver). They didn't have the parts in stock so it will be back next week. I'll find out more hopefully when I pick it up this afternoon.
I've Had The Same Problem. High Pitch Chirp/ Squeak Under My Front End. I've Taken It Everywhere No One Can Tell Me What It Is. Please If You Figured It Out Tell Me. Thank You
if i remember correctly bushing in the upper strut mount allows too much travel between the upper mount and strut. Sentry West in Shrewsbury, MA found it for me. g'luck. I can get the formal info in a week or so. they said its not bad to drive on just an annoyance that can be fixed.
