Damnit... 626 manifold must be making something if you're making that much.
From near as I can figure, you're 20 hp to 30 hp above me... when we dyno the JDM FSZE, we'll see how much more hp the FSZE compression really makes versus the Asian/Aussie compression... I'm betting about 10 hp. That still leaves 10-20 hp... but that's still not fine-tuned, right?
I'd like to know how you did the 626 manifold. I've got three manifolds on the floor at the shop (borrowed from a friend). One FSDE, one FSZE (resonator box is the only difference) and one 626. The 626 is about three or four inches short of the VICS long runners, should be good for mid-to-high rpms. Depending on where you end at, your power gains should prove that it's a good idea even for NA.
