Alternators
Actually, an alternator will put out voltage relative to how fast it is turning, the faster it turns the more it puts out so that's the reason for a voltage regulator, to keep the final output voltage within a set range.
Recall that voltage is the electric equivalent of pressure, current (amps) the equivalent of flow rate, and ohms the equivalent of resistance to flow. Incandesent bulbs have high resistance, which is what makes the filament glow, so the current has to push hard against this resistance. That resistance does back up all the way to the alternator.
As you put more load on the circuits the magnet field resistance increases at the alternator and it does take more energy to spin the stator against that resistance. Now, in todays electrical systems, the resistance variation probably doesn't amount to a whole lot since all the electronics in today's vehicles require a pretty stable power supply to keep from frying or misbehaving. But every little bit helps.
The move to solid state lighting is for durability, lowered power consumption resulting from less resistance, and increased fuel economy from the lowered power requirements.
In this case, the need for resistors to keep the flash speed normal negates the benefit of the LED's so there isn't much point in the swap.
Ted
Ted
