LazerBlueP5
- 2012 Cadillac CTS-V Coupe // 6spd
what did the guy do in the vid? WOT and then hit the clutch real quick?
and AT is better for dragging anyway
5k for launching is to high they should set it up to 3 .5k
3.5k would still be too high. Some where between 2.5k - 3k would be more ideal. - You don't want copious amounts of torque being unleashed all out once on a FWD platform. I imagine this car would be running the 1/4 at around 13.8 stock if it came with this technology. However, I personally perfer the satisfaction of having felt like I had more to do with the time than some electronic gimmicks doing most the work for me.
nah i still almost bog on 3.4 k. you gotta think when your trying to launch at lower then 3k your sliping the clutch till the car gets up to speed not side steping the clutch. you try and side step the clutch at 2.5 K that car ganna try and stall and buck hard once.
Really? Whenever I tried to drop the clutch out at or over 3k I got tremendous wheel hop and or spin witch lead to a piss poor launch, torque steer and misalignment. Maybe that is due to tire PSI?
- My best 60ft is 2.0 and that was achieved with a quick slip of the clutch at 2500rpms. ET ended up being 13.97
I ordered just 2 step Im not into this shifting thing.....
i dont have stock rims.....and more mods are coming.....
so rims give you traction? Good luck with everything man hope it works out for you.
