I Cant figure out what size/offset to choose!
Shervin
I plan on going for the 5zigen ZR series
http://www.5zigenusa.com/english/products/wheel/proracer/ZR+520.html
Deep Type 1 187.5J I'm going to go for but I cant figure out what offset will work best with stock suspension. +47 or +52? I would like to get the Hyper Gunmetalic :) My MS3 is a 2007 Black GT
I want to keep it as close to the stock rim as possible But I dont know the stock rims off set. Can someone tell me
Anyway what do you guys think/recommend?
thx!
thx!
Ok so I ran your numbers in a wheel offset calculator
Stock setup ran as 7-52mm
Vs. 7.5-47mm
The clearance from stut housing to the inside of the wheel will be 1mm LESS
The outside edge of the wheel will EXTEND an extra 11mm
Vs. 7.5-52mm
The clearance from stut housing to the inside of the wheel will be 6mm LESS
The outside edge of the wheel will EXTEND an extra 6mm
I am not sure exactly what you mean by "closest" to stock, but if you are trying to say that you don't want the wheels to stick out too much, then the 52mm offset will be closest stance to stock.
Vs. 7.5-47mm
Vs. 7.5-52mm
That is what I meant and thank you for the information! Going to order me the 52mm offset! Can't wait for these to arrive :)
*Thank god I did not order... I finally found the weight of the rims... 26pounds.. No thanks. But they look so sexy >.<
