- i have a wire tapped into the ^^^^above wire a couple inches before the sensor that is grounded to where the "Stock" water temp sensor is towards front of engine.
That's why your gauge isn't working. The temperature sending unit is grounded using the ground from the gauge, not the signal wire. Disconnect that tap and you'll be good to go.
