Day light
Tommyspeed3
Mazdaspeed3
Hi to everyone! I just want to know if there is a way to turn on the day light in the US Version? cuz I saw the canadian and euro version has the day light.:confused: or maybe Im wrong...
Daytime running lights are half voltage high-beams. There's a pretty cheap module you can get up here from Canadian Tire for older cars, but I'm sure there must be some kind of similar store down there that might carry something like that. It's not a legal requirement down there as far as I know so it might not be as easy to find, but I'm sure there's some auto specialty stores that may carry something like it. Or you could order online from a Canadian store too.
http://www.canadiantire.ca/browse/product_detail.jsp?FOLDER%3C%3Efolder_id=1408474396673462&bmUID=1211605743536&PRODUCT%3C%3Eprd_id=845524443278206&assortment=primary&fromSearch=true
Or check out the 45035 module from this manufacturer which is a high-beam reduced 60% module. They have an application guide so you can find the correct one you need.
http://www.hamsar.com/drlkits.htm#1
Are you talking about actual DRL's, or the little light above the high beam on European models? The latter are called city lights.
If that's what you're talking about then there are a few people at mazda 3 forums working on a retrofit for both 194 sockets, and LEDs.
Oh thanks man I will check it!(burnout)
