so what if the springs aren't colored... which do i use? mine didn't come with any instructions and i didn't get any shims.
If you compare the springs to each other you should notice that the coil thickness varies, the thicker are the stronger springs.
Patty, is it bad to run the heavy spring? What could this do to compromise the engine or This particular little turbo ? thanks
I noticed on mine the color was there....but barely visable.
