If you already had a Cobb SRI and a CS MM insert what should be next if you only had $150 to spend. (Engine Performance only)
Test Pipe to replace 2nd Cat.
Forge BPV.
Boost Tube Kit.
TWM Shifter Base Bushings.
Anything I missed?
You need to be able to properly monitor your engine. It may not add power, but it might help you keep making power. Budget for a boost gauge.
you dont boost gauge now for almost stock car......when your mods will get more serious then buy a boost gauge
