is it okay to have leaded 120 octane gas mixed with a little unleaded gas? ill be going to the track soon and they have 120 octane leaded... and since i wont have cats, for race use only, i can run leaded gas... i was just checking just in case i couldnt empty out my gas tank... and im sure race fel will make a difference?
for starters, unless you can tune for 120 theres no benefit..
If you are still on the stock ECU, it has a limit as to how far it can advance the timing.......
Secondly, i wouldn't blend fuels...idealy if you are going to run a 120 race map in the future, you would install a drop tank for your race fuel...and swap over at the track.
