Since the recall notes a build date prior to 11/22/07, I would highly doubt any '08.5 would be included.
Build date probably applies to the pumps. Since the ECU adjustment is new, any car within the vin range can get the reflash.
if i do end up buying it, im going to make them reflash it whether or not it has the symptoms, to cure my paranoia.
called mazdausa and the closest dealership since my '08 falls in the vin range, but i have no known issues to complain about.
mazdausa didn't have much info because this is a tech bulletin, which i figured, but the local dealer contact was very cool. he said the reflash typically needs to be done as protocol for the problem detailed in the TSB. He said reflashing with that update, for s**** and giggles, especially based on such a TSB, can actually cause more issues if the car is not seeing the issues based in the TSB. he said there is a seperate list of applicable ECU updates that would show up for my car when he ran the VIN and queried and he said currently there is nothing that is available that is a general program update for my car.
i can tell already this thing is going to turn into an internet legend....claims of incredible gains through a reflash on a car that was just fine to begin with....
the bottom line surely seems to be this - if you car is acting fine and/or you don't have any codes, then IGNORE this TSB
http://www.o-m-g-w-t-f.com/stuff/Maz...19b[1].pdf
Theres the link to the TSB, its any MS3 with VINs lower than JM1BK**** ** 859606 produced before November 22, 2007
Mine was produced in 02/08 but falls within the VIN range and the dealer said it did effect mine but dont worry about it unless it shows the symptoms
Seems odd that your vin is lower than 859606. My build date is 12/8/07 and the vin is way out of the tsb range.
VINs have to roll at some point. Probably about a month before they started producing the 08.5s.
