Forge motorsports BPV
nytmar3
Mazdaspeed 3
friggin sweet piece. Looks good, sounds good. Easy install. Doesn't leak. I'm loving it.
so what spring is everyone using. When I get mine i will add just the blue spring...but everyone seems to be adding shims..
I just ordered mine, can't wait to install it. I think my stock bpv was starting to go bad, I can hear it venting while driving normally.
what spring is best for the MS3? and is it in my best interest to use shims or not? thanks
what's up with some people sayin it has a weird sound when it blowsoff?
is it loud ? i don't want something much louder than stock
thanks
Forge says to use the blue spring, no shims.
thanks
It is louder than stock. The loud part is the ping sound heard while in operation. Do some searching around and you'll find some videos people took of them running the valve.
Its louder than stock but still relatively quiet compared to other valves.
I started with just the blue spring, it would blow off under barely any boost, so I tried the red spring and noticed some surge/flutter when under boost and slowly letting off of the throttle. I've settled on blue spring 1 shim.
No, flutter and surge are different things.
Edit: Red is a little strong for stock boost levels.
