I also heard the ATP does anywhere between 8-10psi, it's like random or something. Can someone confirm this?
i would have asked how you knew what the boost level was w/ no mods, but since you covered that base, instead I'll ask where the heck you are finding stock MSPs... cuz clearly there are some owners that need to be informed of what they're missing out on!
We offer four springs:
Green - 5-10
Yellow - 9-14
Blue - 14-18
Red - 19-24
You adjust throughout those ranges by way of the threaded turnbuckle on the end of the actuator rod.
newb question. I just ordered a Forge wga with "9lb" spring. if 'when' this gets installed and i test out to only 6lbs. will this be able to be adjusted easily with it still installed? or does it have to come out completely to adjust it? thanks.We offer four springs:
Green - 5-10
Yellow - 9-14
Blue - 14-18
Red - 19-24
