has anyone had any luck with finding the eclipse flange adapters?
EDIT: digging around on HKS' website and google, i was able to find a part #71002-AK008 that seems to resemble the flange that mach 3.5 used (middle one on the right):
the thing is, HKS lists it as a 35mm OD. if memory serves this is around 1.3". i know that a 1.25" OD is needed for this setup. is .05" truly a mitigating factor as to why this flange would not work with the setup?
hopefully someone knowledgeable in these things could stop by this thread.. thank you
