thestone11
I changed mine at 130000km~! still looks good when I took it out~! not really that worn down~!
I have, ive been through a motor (not my own), plus xelderx has done about 5 built motors and confirmed it. its not interference despite how its documented.
I will now be able to sleep a bit easier if I push the belt change...as I said, I had an Acura 2.5TL (5 cyl) which did have an interference engine and that was getting scary approaching 100k miles....likely a ton more money than the P5 motor if I did break it...
I still prefer timing chains, but am enjoying the P5....and am very pleased to have been wrong about the FS being an interference motor.
ps--man, this is a nice, busy forum--good guys for info, etc. (I've been on guitar, other car forums, for well over 12 years now)
George
That would've been the water pump belt. That's why the car still ran fine. That's why it overheated, because the water pump wasn't turning. That is not the timing belt, it's a drive belt or accessory belt. The car WILL NOT run with a broken timing belt.Well....
one day was driving from home to work and then BAM@@@!!! at the moment i did not know what happened so i kind pulled over and everything seemed fine. car was on no noise so yeah and it was not jerky or anything... so i drive a block so i overheat... so i pull over and turn car off.. and pop the hood an wow... no belt just pieces everywhere.
so i towed it home and put a new belt.
Now i dont know how it happened and i asked greasemonkeys and they said have never heard of such a thing. blah blah .. so i gave up and forgot about.
03' auto at roughly 45k
Another factor in all this is temperature. I once saw a spec on some Mazda that said 60K change, but 100K miles in California. I thought, well CA cars are sometimes different for emissions etc. But no, it was due to whether or not the car was to be operated under say zero degrees. It makes sense that the belt would be stiff & brittle, plus try turning over those TWO -15 degree temp camshafts, pushing on 16 springs, all coated in syrup (0W30 anyone?) So, since the original poster was in MI, I'd say think hard about keeping the belt past next fall. What I also wondered was if using a belt day after day in real cold weather expedites its ultimate demise due to the stresses - i.e. after 50K in Manitoba, a move to Key West might not ensure a 100K life.
I was poking around the regular Protege forum, and there was a guy in Virginia who had 193k miles on the original timing belt on an FS motor(!?)
Then again, I've got a Ford van and in one of the Ford truck forums, there was a link to www.millionmilevan.com about a guy who has a million miles on a '97 Ford van. He went over a half million on the original serpentine belt, and still has the original radiator hoses on the thing...rubber parts are sure better than they used to be...
George
