Direct Injection Systems
mrlilguy157
07 mazdaspeed 3
I'd like to request this as a sticky item.
First off, don't even start reading this stuff unless you have a solid 30-45minutes to devote to it. Get ready to think.
Holy cow guys, piggybacks are obviously not an effective way of tuning these cars, but they are indeed the only options at this point.
Cobb for the win at the moment, hopefully that is proven beneficial. As theyve stated publically before, throttle control is not something that is NEEDED.
Any company that is looking into tuning these cars or squeezing more performance out of them needs to forget about throttle plate control, AFRs at this point, and injector timing, and go back to square 1, and figure the sole purpose of direct injection technology - other than the general facts of 'environmentally friendly', a 'cooler (temperature) combustion chamber', and 'higher compression ratios'.
A famous quote we all know, You dont know where youre going, unless you know where youve been. Tuning these DI cars like a port injection car is not possible. They dont function the same, they were not designed the same. They have different goals and drastically different technologies. All of the data and documents Ive scrounged up seem to be a pretty informative overall.
I'm no programmer, but as far as I can tell, the simplest changes need to be made once the ECU is able to be modified directly.
1. Boost Level (through factory boost solenoid)
2. Commanded AFR (12:1 when possible - not everywhere)
3. Timing Map changes (conservative, aggressive, and 100oct race mode, as well as custom tunability for dyno/custom tuning and extreme setups)
1) With these 3 changes being directly related to the ECU, without a damn piggyback, the ECU can utilize the full 2bar MAP sensor to read up to 29.4psi, and adjust boost accordingly with the solenoid controlling the wastegate. The ECU knows the real level of boost pressure, no tricking. Tricking the ECU doesnt work as effectively. The car freaks out and goes closed loop. By allowing the ECU to truly see everything, it can perform all of its changes NATIVELY.
2) The commanded AFR can be obtainable with the upgraded pump for sure, at most points. No person will run out of fuel above 4k, and below it, I'm not concerned with the AFR's whatsoever - in all honesty. Reading through these articles, youll see relatively new technology and terms, such as ultra-lean burn technology, or lean-burn engines. These terms and ideas are directly related to the direct injection motors. Even being lean in the bottom end, Paleriders graphs (most recent dynos, with the new pump) still could not obtain the 12:1 AFR that most port injection cars desire when upgrading.
Palerider said:
This one is at 17 psi from today. It also has the upgraded pump.
Further looking at the graph, when wide open throttle is applied, he was seeing maybe 500rpms of dangerously lean conditions (16:1 dropping to 14.7:1 (stoich)), at a rather low RPM, which is expected with the cam driven fuel pump. Also, in the bottom end, I wouldnt consider this tiny lean spot too much of an issue there isnt enough air flowing nor is the motor working hard enough for something devastating to happen (IMHO). Those readings are also based off of the sniffer, which pushes the AFR UP in the power band. In actuality, the lean spot is even lower.
And Ill quote myself from another thread in responses to Jordan from CP-E, pertaining to this chart that I made as well:
mrlilguy157 said:
When it comes to producing power, we want the cars tuned for more fuel in the bottom end, and less fuel in the top end, something closer to stoich (12.8:1 is the highest AFR Ill go in the top end when the car is trucking along) , not 10.5:1 AFR. I also wonder the same question about running the car so lean before 3500rpms, or do I? Doing simple Google searches, GDI systems weren't all about power in the initial designs, before patents were issued. Back in 1997 when Hitachi introduced GDI systems, the main goal was to be more environmentally friendly, being able to run leaner mixtures safely, to make the trees greener and the ozone layer to stay together. Not suprisingly however, being the power-hungry enthusiasts that we are, we enjoy the torque and acceleration.
The graph which I composed was a mixture of data directly from APR and from Autotech. The numbers for the stock hitachi fuel pump were taken directly from APR's site, for they've got the 1 of 3 in the nation CDFP testers at $80,000, and I don't. I took the numbers they have on the chart and then compared the projected HP line of the APR FSI pump upgrade, which is advertised at 42% flow over stock, and verified this with the chart posted for all to see. Then, taking Autotech's data of 50% over stock flow, I created the graph which Jordan posted in his response. That is the only place those numbers have come from, directly from the manufactures, no where else. Yes, there is more flow up top, for its a linear 40% or 52% over stock flow levels, from the bottom to the top, linearly. The increased inner piston diameter across the stroke of the piston in and out of the pump is what allows more fuel in the pump per stroke, creating more pressure at more volume.
I don't know everything about the GDI systems, I'm leaning daily, more and more as I talk with more tuners, companies, testers, and drivers; I hope all of the input provided helps in some way....
Note: I edited a few things for clarity in that last section
3) The timing adjustments would allow to retard ignition timing for the big turbo guys, but the stock ECU has an INCREDIBLY conservative timing table. Thats why you're not even messing with it with the StandBack unit with the stock turbo users (majority of standback users). Laloosh didnt play with timing grids, and neither does/did dada a few months ago. He came out and said that increasing the timing by 2 additional degrees yielded about 3hp gain, and it wasnt worth it, for the risk factor.
Moving on:
Here are some excerpts from articles and patent documents I've been reading. I'm freaking excited. A lot of this stuff is nerd talk, some of it over my head at this point
My comments about the ECU using the throttle to regulate boost pressure are also mentioned in this stuff. What the hell? The current tuners have no idea what they're getting into as far as I'm concerned, or maybe they do, I don't know, but I feel as if the current progress being made is completely pointless. In my opinion, the Xede and Standback are heading down the wrong highway, Cobb is doing the right thing though, and I completely understand why they have no software out and they are only guaranteeing their tunes with their bolt-on mods. By tuning the ECU directly in relation to all of their mods on their test car, the algorithms modified and the maps created may not act well with different modifications. Sure, the ECU has its built in room for play in the tunes, but really how much play is there? How much correction can the ECU do given that there are literally dozens of variables which come in to play? Cobbs user tunable software is going to be pretty advanced, and need tons and tons of control over everything. A well qualified tuner is going to have to play with this stuff. For simple input fields, like a 30x30 grid of timing modifications, there is going to be A LOT of calculating behind the scenes in order for everything that relates to why the stock ECU would change timing, to still be functional.
As Jordan and I have been discussing in mazdas247, and further ProtegeGarages forum, (GT3071r Thread, pages 8,9, and 10 IIRC), the ECU goes into closed loop when injecting a ridiculous amount of fuel in the bottom. Sure, the upgraded fuel pump has ability to keep the fuel supply going at the right pressures, but does the ECU know that? Well, thats a loaded question. A piggyback for the ms3 isnt controlling the injector pulsewidth vs the pump solenoid together to keep parameters under spec, therefore the ECU goes closed loop. Someone hurry up and crack these ECUs, or come out with a true standalone. That would make this all the much easier.
This further goes back to my belief that piggybacking the ECU is not a good idea for more advanced tunes. With modifying some things, but leaving other things untouched, the ECU freaks and goes closed loop. Bad news. That means the ECU is resorting back to limp mode, being that its running a guaranteed map which will not cause harm to the car, yet the car is still functional 100%. The sensors are doing next to nothing its in its own safety zone, until the sensors feed the right voltages to the ECU, in which itll open back up and try again. No Atari 2600s here :D = ken.
Anywho, check this out:
Abstract info about DI systems:
"A method and system for controlling the air charge in a direct injection spark ignition engine that provides proportional plus integral control in positioning an electronic throttle control valve and an exhaust gas recirculating (EGR) valve in order to compensate for uncertainties in the EGR valve flow area. An adaptation algorithm is used to improve the estimate of in-cylinder flow and throttle open-loop control. "
and claims, as well as other nerdy info:
"1. A method of controlling air charge in a direct-injection, spark-ignition engine having an exhaust gas recirculation (EGR) valve connecting the exhaust manifold and intake manifold of the engine, and an electronically controlled throttle (ETC) valve controlling air flow from the atmosphere to the intake manifold of said engine, comprising a sequence of the following steps:
generating an intake manifold pressure value [solenoid boost level sent] which is indicative of measured intake manifold pressure [MAP sensor]
determining a desired intake manifold pressure value;
determining a desired EGR valve position;
determining a desired ETC [electronic throttle control throttle body] valve position;
adjusting said ETC valve position in accordance with said desired ETC valve position; and
adjusting EGR valve position by an amount that is proportional to the error and the time integral of the error between said actual intake pressure value and said desired intake pressure value.
2. The method as set forth in claim 1 wherein said desired intake manifold pressure value is a function of engine speed, and demanded engine torque.
3. The method as set forth in claim 1 wherein said desired intake manifold pressure value is derived from the following equation:
p1,d =Wcyl,d *T1 /(k0 (N)*N)
where;
Wcyl,d is desired total mass flow rate into the cylinder,
N is engine speed, T1 is intake manifold temperature [note: weve seen how intake air temperature plays with the throttle and timing], and k0 is a calibratable function.
4. The method as set forth in claim 1 wherein the EGR and ETC valve positions are determined in accordance with the following equations:
uegr (k)=uegr,d (k)-kp (p1,d (k)-p1 (k))-ki Z(k)
Z(k+1)=Z(k)+(p1,d (k)-p1 (k))*ΔT"
source
So, really, there is some simple algebraic math equations there, and just by looking at them, and what each variable stands for, you can see how and why the throttle is constantly adjusting and I dont care! Now, if we would like to solve this equation, its not that easy. Weve got 2 variables were solving for. p1,d and k0. .k0 is the secret algorithm based on Fords programming, and the p1,d is the output based on all of the sensors coming into the ECU.
Ill let the ECU do its math like its trained to do.
Moving on to more readings, any person who has taken out the swirl control flapper system in the intake manifold is hurting the projected functions of the ECU.
More stuff: Toyota's GDI system:
The D-4 incorporates a highly optimized combustion chamber: The piston crowns are fitted with a lipped, cup-like formation that focuses the injected air/fuel mixture tightly around the spark plug for maximum burn.
Intake air is drawn through helical ports that create a high degree of horizontal swirl, which Toyota says combines with the lipped combustion chamber to not only maintain highly stable combustion -- a quintessential problem for lean-burners -- but also to stratify the air/fuel mixture.
Additional swirl is promoted with special swirl-inducing high-pressure injectors. The end result is a fuel-rich mixture in the direct vicinity of the spark plug, with extremely lean air/fuel ratios near the cylinder walls.
Now, youll see the mentioning of helical swirl ports, which cause the air going into the engine to sort of be tumbling and spinning around. When the air gets in the cylinder, it is moving around, and fuel is injected, to where there is proper and complete atomization. The DISI head doesnt feature helical ports, I know this because there is a new cylinder head sitting next to me on my dresser. Instead, we do have the swirl flappers built into the intake manifold. As these flappers open and close rather quickly, the swirling motion is created for optimum atomization between the air and fuel.
Source
Okay, so there is 2 nice things right? Well, look at the date of that article - 1996. That was wayy early in the game right? Right - and that technology has only become more complicated as technology has been able to take over, and costs have come down with higher demand from automotive manufactures all over the world. In looking up information for my research paper (over optimizing performance output of an internal combustion engine, of course (yes) ), I have found this article here:
DI Motor
Uh oh, Ford has been using these motors in Austrailian cars? XCORP was founded in 1991??? Its apparent that Ford has been working with these guys. So anyways, thats nice. The DI system has been licensed to Ford and GM, as well as Mercury ( a boat engine manufacturer). Wow, crazy to see that Ford and GM both released their high output turbocharged DI motors within a year of eachother (sarcasm)
And, look at this, too. The special piston designs from 1996-2003 were replaced with the flapper system in the intake manifolds, which cause the air to tumble into the cylinders, the swirl effect, exactly the reasoning for the goofy shaped pistons in the preliminary GDI designs. The usage of swirl valves causes a spinning air movement, like a tornado turned horizontally, rolling like a barrel, which causes atomization of the fuel and air together in the cylinder, instead of the goofy darth vader mask pistons which do the same thing at more $$$ to the manufacture, and more research and design.
Darth Vader
So, in essence, lets stay simple we can if thats even possible with the direct injection technology.
This is all coming together with me. Even if this isn't new news, my brain is hurting from learning and understand more. I don't trust any person who isn't familiar with tuning DI cars. Tuning these cars (mazda DISI) vs. port injection cars: the systems are different entirely, although a goal of 12:1 is a okay, I don't want it there in the bottom end, where the motor isn't working too hard. I want it leaner, just as shown with this stuff. The leaner burn is efficient for the tumbling air, and its all part of the design of direct injection motors (fuel efficient and environmentally friendly!!!!). Up top, we're welcome to tune to 12:1 or what have you, no biggy. Higher can be safe with the tumbling air, I dont know... just read all of this stuff, particularly the first 2 sections. The 3 valve benz stuff doesn't pertain to us.
Stuff
The documents may be of age, but the goals are all the same, the systems, concepts, etc, all the same. I've found articles from 1948 on compressor maps for turbochargers which still apply today, even more so actually, so don't let 10 years of history and design modifications scare you off from these ideas
(yippy)(yippy)
Bravo to you sir!! Fantastic write up here. I have learned a ton from reading this. And in the virtual world of online forums where 95% of the time you feel dumber for reading what you just did, this is a very nice change!! (drinks)
Good stuff.
So what I'm wondering is how far our injectors can go? The turbo kits for the VW DI motors upgrade them. Will we have to, I'm suprised people are not following the VW scene more closely. They are ahead of us right now it terms of resarch and devolopement.
Any opinions about injectors?
Have you found anything that talks about injector timing and duty cycle? That still seems to be a confusing point.
I think there is a little confusion over open/closed loop control.
Open Loop: No adjustment, relies on set parameters. Also occurs when there is a sensor error.
Closed Loop: Checks commanded AFR vs resulting AFR, and adjusts parameters according to some transfer function to try to obtain desired result.
An ecu that is "limping along" is running open loop, on some base "I know it will work map"
The reason you guys are getting confused about injector duty cycle/timing is because it is a completely different design. With the injector in the cylinder it cannot inject 100% of the time, if it could you would be injecting during the exhaust stroke and accomplishing nothing.
In an idle/fuel efficient mode, the injector fires during the compression cycle, injecting a small amount of gas and keeping it close to the spark plug, thus resulting in a combustible mixture close to the plug but with the rest of the cylinder in a lean condition
In a stoichiometric mode the injector is fired during the intake stroke
In full power mode it is also fired during the intake stroke
This means that under full power, high rpm your conventional injector "duty cycle" can be no more than 25%
What I don't get is how the cat works in combo with one of these systems. The chemical reaction in cats only occurs when the engine is running very close to stoich. Running in a lean burn mode produces alot of Nox, but not enough hydrocarbons for these to be converted back to N2, H20, and CO2.
I wonder if the cats are different from a standard injection vehicle? The catalyst brick itself could be a significantly different composition. The easy test is to slap on a Magnaflow/Carsound cat (which is EPA/CARB approved), and do a before/after emissions test on the rollers.
The EGR system helps reduce NOx a lot, which might explain why the emissions are still within normal specs. I don't know about our EGR systems, but on a lot of cars it actually is bypassed at idle and at WOT/high RPM.
This thread rocks though. I'm glad to see people looking at the big picture rather than the constant stream of worthless "which exhaust is best" threads.
What I would really like to see is someone with a test engine try to run dieselish by injecting in the power stroke. Would alleviate detonation problems while allowing you to pack in more fuel to the stroke. Would have to be cranking the PSI or running N20 to get the extra oxygen in though. Very risky.
This means that under full power, high rpm your conventional injector "duty cycle" can be no more than 25%.
I have read reports of people's logs showing 45% injector duty cycle. Does this mean it is injecting during almost the entire intake and compression strokes? Is there some scaling where 45% means 45% of the available useful injection time? More confusion. (huh)
I think a big problem here is not having proper definitions for all the terminology. Is the injector duty cycle a percentage of the full cycle (two revolutions) or one revolution, or a percentage of some predetermined arc of travel of the crankshaft that we know nothing about but the ECU keeps track of? Way too many unknowns to speculate without more information.
Injector duty cycle is [SIZE=-1]the percentage of time the injector is supplied with power.
Injector pulse width is [/SIZE] the time during which the injector is powered.
Explanation
Only mazda/someone who has been in the brains of the ECU could answer that.
If they are using an "absolute" duty cycle then yes, they would be injecting over the majority of the intake/compression strokes. Where it gets interesting is if you are using the duty cycle of the injector as a measure of "useful" injecting time then that useful injecting "time" decreases dramatically with the RPM increase. Thus even if the injection period remains the same, the duty cycle will go up as the RPMs increase. Makes for an interesting study.
Here are the advantages of direct injection as I see them:
1. Allows increased valve overlap without blowing fuel into the exahust:
This allows the gasoline engine increased "scavenging." Results in a more complete exchange of air particulary in turbocharged vehicles, thus a cooler and fresher charge, particulary at low RPMs. More torque down low.
2. Lean burn at low power demands: Increased efficiency at low power demands. This doesn't apply as we are running slightly lean at idle, but an efficieny minded direct injected engine would be running at 30-40:1 under low power conditions.
3. No need for a butterfly throttleplate: Increased efficiency from eliminating pumping losses at partial throttle. In theory, the power demanded is supplied by the duty cycle of the injector. Not applicable to the mazda DISI because it doesn't run in a "lean burn" mode.
4. Injection during compression cools the charge, fending off detonation. In theory allows higher cylinder pressures with lower octane fuel without detonation. The mazda's ratio is like 9.3, which is on the high side for a turbo undersquare gasoline engine running on pumpgas, but lean burn DI engines run ratios around 11-12:1. Could mean we have a significant amount of boosting headroom without causing detonation.
Disadvantages:
1. Requires high pressure fuel supply. Added weight form the heavier duty components, and fuel pump requires more power to drive it than a standard system.
2. Reduction of injection time. Can't inject during the exhaust/power stroke like a standard engine. Means the injectors must flow more than twice as much as a standard engine with similar charistics. Fuel pump supplies fuel linearly with RPM, but demanding a low AFR at high RPM thows it for a spin. This is why I think the throttle plate closes at high RPM. The injector was sized such that it performs well in the low/midrange but gets overloaded under very high demand. Increasing fuel pressure will help, but adding another fueling source would probably be best, gaining control of the throttle plate and adding a meth injection system would probably do wonders for the top end, even without upping the boost.
3. Injection timing becomes more complex and important. If you always want to inject during compression, then as the RPMS go up and/or the commanded AFR goes down the injection start time changes, but not the end time.
