I've now got all the parts in hand to install the AVIC-D3 along with bluetooth & XM add-on's, and back up camera. I'm laying it all out and making my plan and I had a few questions:
1. Where did you all mount your navigation antenna? Did you actually run it outside, or above the dash, or somewhere else inside? I'm going to have an XM antenna also so I'm debating where to try them on the dash, or possible on the small sill in the rear side windows. Not really wanting to run wires outside, and I had an XM antenna in the 3rd brake light of my old GP and it worked perfectly.
2. Do we need an antenna adapter for the factory antenna? I didn't get one with the "installation accessories" and don't see one listed on Crutchfield so does our antenna plug right in?
3. Does anyone have a wiring diagram or know which wire is the speed sensor to tap into?
4. Back-up light-anyone have the wire? I know I can pull the harness from the taillight and figure it out but if anyone whose done it has the wire it might save some time.
5. If anyone has this with the Bluetooth add-on, did you have to use the mute wire? The bluetooth manual does not mention it, and the D3 manual just says "if you use equipment with mute function, connect that equipment to the audio mute" otherwise keep free of connections. Is this needed for bluetooth to mute the radio when the phone rings? Or is it just saying that if you mute the radio (with the mute button) it won't mute voice navigation or the phone ringing? The only reason I really care is that the instructions I got to overide the safety feature includes pulling that mute wire and using it elsewhere.
Any other tips from those who've done the install? I had previously purchased the Scocsche kit and had it dipped piano black so I'll definitely post up pics when its done. I'm hoping to get around to this by early to mid February.
