- 2003.5 Titanium MSP
stock boost. stock everything. 7psi I suppose. whatever they set it factory.
I guess you might also consider the fact that all people claiming ther boosting only 4.5 and those boosting different are also using different boost gauges from different vacuum sources..which could make them all read different even if they weren't.Well, don't you have a boost gauge ?? that'll be more accurate cuz not all MSP come stock from factory at same psi boost rate, there's ppl that were boosting 4.5 psi stock so ........... the boost gauge should be more precise (mswerd)
wow u just answered all my ?? in 3numbers props dude nice thats is a good gain!!!!
Where the hell are the moderators? This drama should have stopped at page 1.
Just telling it like it is. It is easy to beat stock manifold because the design is truly horrible. My manifold tested slightly better than the Thunder at stock boost and if you add the known improvement from the Thunder then you arrive at a similar result to the RPM and that result is also close to the MAM. Nobody is breaking any new ground here as far as performance goes. Naturally some higher boost will separate the men from the boys but stock boost isn't going to show much difference between any of the aftermarket manifolds.
Is there any way someone can test these mani's at 10 psi and display
the dyno sheets???
10psi and what supporting mods? stock turbo? be a little more specific....or do you just want someone to crank 10psi off stock? I wouldn't. Don't wanna goo zoom boom boom.sorry. I'm a wuss.
Also I am not sure don't quote me but I think steed said his mani can
possibly out perform the others at higher boost I would like to see
facts before I put my money on anything....
