Anyone know where I can find instructions online? I bought one from a board member and he did not have the instructions.
Thanks....
http://www.injen.com/galleries/products/41220071305SP6062_hd.pdf
edit:: this one says you need to remove the front bumper, but I was able to do it by just removing the drivers side wheel and the splash gaurd. I've heard mixed reviews about which way is the best way, but I was to lazy to remove the bumper.
You clean it, but not like K&N. It comes with cleaning fluid. Here you can find the instructions for cleaning and you can buy the cleaner too.do you clean it like the k&n, oil too?(uhm)
ya, we cleaned it with soap and water, NO oil though!! thanks!You clean it, but not like K&N. It comes with cleaning fluid. Here you can find the instructions for cleaning and you can buy the cleaner too.
http://www.aempower.com/cleaning.aspx
Yeah, soap probably works fine. However, follow their method with the bucket or you risk transferring fine particles to the inside of the filter where they will go right into your engine.ya, we cleaned it with soap and water, NO oil though!! thanks!
