dadasracecar
You guys crack me up.
Laloosh made a comment about not wanting to set the Boost Clip PSI on the Standback to a value (10 IIRC) when he was mad at cp-e.
AFAIK nobody has done the cp-e IAT clamp winter fuel cut fix b/c the "the car will run lean" and the "fuel cut is there to protect the car."
But a MAP clamp is all good. That way you can run 18, 19, 22 psi with no problems.... LOL.
