5/100 is the bolt pattern; 5 bolts spaced at 100 mm.
People just because an offset "works" does not mean it is good.Try try to stay as close as possible to factory offset. Look really hard and you will find wheels with a 53mm offset. The suspensions geaometry is all designed to work best at factory offset. Rubbing aside, 48 is the lowest number I would even consider. You you not believe the effects of 5mm. If you do not care about handeling continue bolting on what "works".
