I definitely don't plan on modding my down or mid pipe after all this.
Of course putting the cats back on stops it from smoking, that's what the damn things are there for!! To stop overpolution!
It has nothing to do with backpressure or whatever... it means the cats are doing their job.... the turbos are still leaking, it's just not visible anymore and more than likely your cats will be ruined from the added oil... its only a matter of time...
(attn)
I spoke with Jon from CP-E and he said that Hitachi-Warner (the manufacturer of our turbos) had a bad batch of turbos. He said that Hitachi is recalling these turbos which wound up on our cars.
He said its not a normal condition for our cars to smoke!!!
That would explain the new part number Mazda is using for the replacement turbos.
As far as determining if your seals are going bad, I don't think anyone answered my question yet about oil consumption. Basically, is it a safe assumption that if you are not losing any oil between oil changes that your seals are in ok condition?
we need a vin range of those affected...
Can someone call and ask what the vin range is that has the defective turbos. What's the Mazda Tech line?
Turbo is not defective. It is the seals.
I know that, already had mine replaced...just wanted to be clear that the turbo itself is not defective.
