- 2001 Pro 2.0 LX
cool, keep us updated on the specs for rear drum kit diy
Jsut to clear up some stuff:
- Bore out by 0.5mm
-Bellfab Rods
-Unmodified Arias Forged Pistons or do they have to be machined?
-Will the Miata ACL race bearings work for my ZL?
-How about the Head Gasket, did that work direct for u or did you have to shim it?
first thing to find out is if the crank is the same for both the ZL and B6. if so then that's a good starting point....if that's the case you can use B6/belfab rods, B6 bearings, and if the ZM forged arias pistons aren't interchangeable with the ZL (which i think is not the case) you could contact kooldino to go about having them made.
head gasket I haven't figured out yet, cometic looked at my stock zm gasket and couldn't make one from similar templets they got.
That more for repair manual mainly but a very good resource to have. It will not give technical details on the engine like the Mazda Facorty feild service manual would. I'll try and take a picture of the cover this weekend and post it.
if you had a stock ZL rod and piston sent to you could you confirm this?
^ if any ZL person wanted to send in their rod/piston I've got the stock ZM rod/piston to compare
post up or send me a pm
