Aluminum does create an oxide layer, which then in-turn protects it.
The stainless exhausts are great, just they weigh a fair bit more, and cost alot more.
Hopefully the manifold get's tested soon, look what I play with when I'm bored...
Now, this is getting tricky. On-end, it just blows away with the high-freq start, then purrs like a kitten...
Some shim stock, not sure it can be welded butt-joint like the blades, maybe with a backing of copper.
Some close-ups of the thin stuff. The concentration needed for this is more than I could do for any decent duration.
You have to move, move with this crap. First try was comical, second turned out alot better.
