It's me biknman or Dave. Sorry all the pulleys are sold.
I do have the following left for sale:
Set of front AWR reinforced control arms with bumper steer correction ball joints all billow ball bearings (aka spherical bearings) in stead of rubber bushings. $350.00 plus shipping
AWR front adjustable sway bar end-links $30 plus shipping.
AWR full adjustable rear lateral links and trailing arms with billow ball joints and all the correct spacers. $200.00 plus shipping
ACT clutch with an HD pressure plates and new 6 pad (non sprung) clutch disc and though out bearing with stainless steel clutch line. $100 plus shipping
Also found a set of rear APC carbon fiber look rear taillights. Make offer plus shipping
Four stainless steel and one mild steel exhaust flanges for making a turbo or NA header. $50 each plus shipping
Front set of Ground Control adjustable camber caster billow ball strut top plates. $150.00 plus shipping
Rear set of AWR billow ball struts (aka spherical bearings) tops $100.00 plus shipping
And couple of rear CF wings/spoilers one that's straight and one that is 3D in shape and type. Make offer plus shipping
B&M stainless steel short shifter with Kartboy bushings and Kartboy Silver knob all mounted to the linkage for easly installation. $100 plus shipping
Lastly a rear 3gen 4x100 drum to disc brake conversion kit with (must have 16" wheels or bigger) Wilwood Dynalite four piston calipers, Wilwood two piece rotors, Wilwood single piston emergency brake calipers, stainless steel brake lines, all mounted up to the sock spindles ready to bolt up.
$500.00 plus shipping. That's over $1200 in parts and there is no other kit like this out there. FYI Wilwood pads and rotors used in this kits can be found just bout anywhere in the world for replacement as they wear out. Designed to be compliant with the stock master cylinder volume and brake basis valve.
Thanks
Dave
