p5sundevil
- 03.5 MidnightBlue p5
as has been stated many times, heat soak with teh tmic only occurs with high boost/high hp applications as our top mount handles the stock and mildly modded setups just fine. the water hitting an intercooler cant cause hydrolock, thats what happens when your air intake sucks in water and it gets In the engine.
water hitting the IC is actually good in some cases, look at the home built intercooler sprayers out there, what do you think they are doing but spraying water infront of the IC. yah its usually a fine mist but it still hits the IC.
The Only thing I would worry about is rust and Im sure the TMIC material has been treated for that.
I repeat you dont "suck up" water through your IC, just your airfilter/intake.
