speed3shon
- 2007 Mazdaspeed3
here are my initial settings for my greddy profec b spec 2.
these got me where i want to be. 15psi in Low, and 17.5 in High. I may play with the gain, to get it a little more aggressive, but for right now, its good.
Low Settings:
Set - 31% (~15psi)
Gain - 8%
Set Gain (Start Boost) - 116 (11.6psi)
Warning - 166 (16.6psi)
Limit - 10%
High Settings:
Set - 39% (~17.5psi)
Gain - 9%
Set Gain (Start Boost) - 130 (13.0psi)
Warning - 185 (18.5psi)
Limit - 10%
It sucks that they allow you to set some settings in psi, but others (the more important ones particularly, like set) in a percentage... adds a few minutes to the process.
have a full tank of gas... youll use half of it with all the WOT passes you'll be taking...
also: when you are making a WOT pass, ease into the gas... you dont want it shooting up to 20+psi. if you ease into it, you'll be able to see the boost getting too high before things go wrong.
Im still not sure why when you set the boost in 5th gear, it will not match the boost in other gears... kinda lame.
i get ~14psi in first, 15 in second, then 17+psi in the rest....
Low Settings:
Set - 31% (~15psi)
Gain - 8%
Limit - 10%
High Settings:
Gain - 9%
Limit - 10%
