PG Pump Installed
Im TOTALLY joking about the nitrous!! Its got to make you proud of your car and runs when it draws so much attention.... Im just trying to goad you a little. We questioned Driver311 when his times were so groundbreaking this fall. Its cool to see the progress.... it gets us off the couch on the new stuff.
Another local MS3 owner came in and hung out at my work this morning and we were both pouring over the board together.... fun stuff.. and tonight I got a fuel pump headed my way!!
And secretly..... NOS:)lol I'll be the first to break into the 11's.... in tire chains to insure traction....lol.
OK, Sorry I wasn't being clear. It was not a generalization but rather an interpretation of this situation. I never said the track results were not an indicator of a gain.My point was that it seems there was other factors at work besides the pump that may OR MAY NOT have affected the end result on the track.
Secondly we should be looking at afr's very closely with this mod. A dyno is a great resource for fuel, timing and afr data. A dyno run that is done first with a baseline without the pump, and one done an hour later with the pump installed could tell us a s*** ton more about this mod than running it down a 1/4 mile. Don't get me wrong, the gains are both impressive and exciting, I just think there needs to be more data than a trap speed.
Maybe that's me though.
i couldnt agree more. Dynos suck, track numbers is where it as it. Not even the et, but trap speeds. To gain 5mph, you know its doing something right.
some1 wants to pay for my dyno ill be more than happy to go. Untill then my bad graphs and track times is all your getting(drinks). The 13.4 @ 106 was done 3-4 weeks ago in weather that was colder than the 12.9 @ 111. If anything the weather condition were better on the 13.4 run.
Im gonna get a dyno. And I'll do it just the way you mentioned except without the data logs. Although I'll be able to confirm A/F with my wideband. I dont trust the sniffer at my shop so I bought a couple grand worth of gauges, modules, pod.... lol
Now I can resume the power mods. Install is supposed to be 45 minutes.... it'll probably take me the full hour. AND.... my car is CAI, and essentially catted midpipe right now. Id say that its fairly stock. Ive never had fuel cut anyway.
I'll bet multiple dyno's will be rolling in within a couple weeks. Then we'll see.
Bust out your paypal accnt address and ill place money on this right now youngster... I have more experience than your age... (pow). Im glad you have a fluid dynamics book... but i want to introduce you to a guy named " Murphy " and how he can spoil ANY text book equation. You can throw 4 pumps together in a series all you like to increase VOLUME, but it will NOT increase pressure. VOLUME is NOT the problem with the MS3 or MS6, its PRESSURE, which is solely handled by the work of the cam driven high pressure pump on the engine! So you go ahead and wire those pumps in the tank for us, than come back with your results. Ill expect a full apology from your immature, adolescent behavior. Im not willing to take your word on your in-tank solution because i know it doesnt work. Got any before and after datalogs? Didnt think so (blah)
Youngster, that's funny. If you're so experienced old man (pow, back atcha), then you should know that the whole point of increasing pressure is to increase the volume of fuel to enter the cylinder. And if you re-read my post, the pressures stack up when in series as well as the volume AND the rate. The only reason we have such high pressures, is because this motor has a very small window of time to inject the fuel. The concept of upgrading fuel pumps remains the same though; to move MORE fuel into the engine. With this motor, we need to move more fuel in, in about the same amount of time, to get the gains we are working on getting (more fuel). If you are supplying the CDFP with a higher volume than stock, and it is pushing that higher volume at the same pressure, guess what? YOU GET MORE FUEL INTO THE MOTOR!! Mission (damned near) accomplished. Like I said, It's not massive gains, but it is an improvement, and it will help me achieve my own goals with the car. This CDFP is on my list of things to do as well. Before that though, I'm adding a surge tank in the engine bay (if that says anything about my intentions). You wanna know something else? This upgraded CDFP has limitations too (shhh). It can push higher pressures than the stock one, but, you have to remember, it can still only push what is provided to it. Now, on the other hand, upgrading the CDFP will cause it to suck more fuel from the in-tank pump than it is designed to, however, seeing that both our pumps are variations of possitive displacement pumps, I'd be worried about the increased wear on both of thier internals. That happens when you overwork a pump, especially a fuel pump. It's just not the way they are designed to work, that is, unless the PG CDFP is a totally redesigned vacume-styled pump, which is able to utilize suction as well as possitive displacement. I don't believe that is the case. Again, I'm not saying that this is a bad pump, but I am trying to say that somebody WILL max it out at some point, and the only other way to increase the amount of fuel to be delivered at that point, will ultimately be to upgrade the in-tank pump. I never said everyone should do it, or that it is necessary. It is for those who already know that they will be requiring a maximum amount of fuel. I'm doing something called planning ahead. It usually keeps you from messing things up in the future. So, once again, don't flap your wrinkley old gums, until you know what the hell you're talking about.
btw if you max out the pg pump, adding an intank pump would do s***. If your theory was valid, adding a intank pump would help the stock cdfp, which it doesnt.
i went in at 3169 with me in it and im 6'5 210. So it should be right around hwere yours is. I dont know how accurate the the scale is because the other time it was 3360 with me in lol, weird
Wow is that light!
My car 08 sport, weighed in at 3130 without me in it. And I know this scale to be dead ass accurate. With me in it, it came to 3370.
Really stupid question. How loud is your car right now with the TBE, and solid motor mounts?
Is it getting to the point where it is obnoxious?
I think you have the terms VOLUME and PRESSURE mixed up.
Negative... Unless you would like it to be referred to as " Head. "
Volume, an amount of fuel that is pushed by adding two pumps whether parallel or in a series. The volumes pressure, will not increase with 2 pumps. Only volume will ( IE: the amount of fuel being pushed from the tank, through the lines, into the FP regulator, out to the rail and into the injectors.) Adding two pumps in a series or parallel doesnt double the flow, head or volume characteristics of the liquid, but it does increase it by almost 50%.
In a normal forced inducted, fuel injected motor, volume is extremely important as boost taxes the supplied fuel volume. IE: Lightings and Cobras use 2 pumps via Y fitting to add volume to the supply, fuel pressure is not important in that application.
The difference in the MS3/6 application is that volume is adequate for now. Pressure is the problem since this is a direct injected engine. Removing the restricted high pressure pump via cam drive and replacing it with a larger pressure pump, allows more fuel to be sprayed into the engine as boost is increased. This results in a more efficient power making recipe.
Ken pointed out that Mazda obviously engineered the fuel system to meet the demands of the stock spec's with probably no more than +10% overhead ( IE: MS CAI and CBE .) Since this is mazda's first DI engine, im sure they are learning alot, just like we are. Maybe in the future, they will give a little more head room to support more mods from their MS parts. Who knows, but the PG replacement pump does work and its needed for anyone wishing to make 30 - 50%+ power out of their car.
You cant increase the fuel pressure little man if you dont have volume to back it up in a fuel injected engine. Now, we are dealing with DIRECT INJECTION, which is a whole different ball game. The entire internals of the PG pump is redesigned and cnc milled replacement if that means anything to you. The only thing left remaining in stock form is the actual fuel pump housing.
And you are right, someone WILL max it out down the road, but that problem can be dealt with much easier than before. Your insight about increasing the volume of the in-tank pump to fix the fuel pressure problem at the engine holds no merit and is NOT the fix for the stock DI pump.
If you would like to plan ahead, build a larger cam driven pump that holds a larger volume of fuel using incoming #AN fittings, larger fuel rail, 3/8 line and a aeromotive inline pump from the tank. Goodluck on that venture and your " book . " You're going to need it (drinks)
Haltech - enough with the condescending tone.
The guy has fuel pressure logs, I'm not sure what else you want.
And FWIW, running two pumps inline in a car isn't anything new. People have been doing this for quite some time with good results.
The CDFP has a pressure bleed off if it gets too much pressure from the in-tank pump so pushing s*** loads of fuel into it that the pump can't do anything with just gets bled back into the tank. The pump is mechanical it can only get soo much fuel into it since your soo smart you should know that you can't compress a liquid so shoving more fuel into the same spot isn't going to work it will get shot right back into your tank.
I don't see your logic, or how you have tested this. How are you so sure it doesn't increase the potential of the stock CDFP? Considering that I'm the only one that has done this, and that I have seen improvements, I would say it deffinately has an effect on it.
I'm not sure why you keep deffending the CDFP as I have not disagreed with one statement about it. The only thing I've disagreed with was the statement that upgrading the in-tank fuel pump is a waste of time and money. It clearly isn't. By your reasoning, the CDFP doesn't need an in-tank fuel pump at all. It would be able to feed the motor all the fuel it needs on it's own. If that was the case, Mazda wouldn't have put a pump in the tank at all, let alone a descent Denso unit (the stock one is identical to a denso at least from the outside).
I didn't reset my ecu, so my interpretations of the it's effect aren't false. I'm not making ANY claims about throttle or boost. The hesitation upon tip in...gone. Fuel cut...seems to have subsided. Just this morning, I did a WOT pull from low in 2nd to about half way through 5th, all shifting at 6000 rpm (where I always do when I'm "getting on it"). I also dug out from 2500rpm in 5th gear. I was unable to trigger a fuel cut by either of these "tests", even though it was 24*F outside acording to my ambient temperature display. I used to get fuel cut anywhere between 3000 and 4500 rpm anytime it got below around 60*F (with and without the ATP boost cut eliminator which is now removed). I'm not exactly sure what to make of that, because right after I swaped out the pumps, I would still hit it high in the rpm range, but only until I removed the ATP. I was expecting it to cut out and I was even waiting for it, but it just didn't happen. That's with an intake, a TBE, my E-01 (set to hold 18psi), and the fuel pump. No tuner. I'll try it again at 19psi on my lunch break if you want. I'm not saying I won't ever get fuel cut, because I don't have any data to make such claims, just like you don't have any data to make the claims that you are. I don't have a laptop anymore since it was stolen, but I still have my AE logger, so if anyone around St. Louis/St. Charles MO wants to do a ride along with thier laptop to log at least what it's doing now, I'm game. We could compare those with logs posted of an MS6 with similar mods. I know it's not the same as using pre-fuel pump logs from my own car, but it's all I can offer at the moment and it could give us a vague idea of what is going on. I had plenty of pre-fuel pump logs on my laptop, but like I said, it was stolen.
BTW, adding an in-line pump has the same effect as upgrading the in-tank pump (sending more fuel to the CDFP). So, if upgrading the in-tank pump is a waste of time and money, then so is adding an in-line pump.
All I'm saying is that more data needs to be collected and examined to draw any credible conclusion about the in-tank pump. As it stands right now, I'm the only credible source that has any experience with a better fuel pump in the tank. Others are soon to follow, and I'm sure at least one of them will be doing before and after logs.
Also, if PG or CP-E wants to bench test thier upgrades with stock supply vs. upgraded supply, I'll send them my stock fuel pump to use, then they only have to get a Walbro unit (which I'm sure they can get ahold of for cheap). At the very worst, it'll work as normally, at the very best, it could push thier pump a little farther. No one knows until it's been tested. I've handled the real world, everyday testing, and have come to the conclusion that not only is it operational, but, at least on my car, it has made thing alot smoother. If you need more proof, talk to CP-E or PG about bench testing or wait until someone that can log gets done with it.
The intank pushes fuel to the camdriven pump, which then pressurizes it and feeds the fuel into the motor. The camdriven pump cant suck fuel from a line from the tank, it needs to have a pump push the fuel to the CDFP/motor from the tank.
cool
yup. but i can tell you for sure that if the intank pump ever does need to be replaced (it probably will, but not for anybody's uses as of right now) a walboro 255lph inline will do the job, and will be a much easier install.
indeed this is true too
conclusion: i dont think the intank pump NEEDS to be replaced, but it doesn't hurt anything in doing so. a 255lph walboro inline can be had for about $150. that doesn't hit the wallet too bad and does indeed add more security, which is never a bad thing.
either way, i still dont think it needs it and won't be upgrading it. i would suggest it to the gt35r guys, if they ever arise.
Yes, it sure does most of the time, but during WOT it is pretty much forced to push as much as it's given minus maybe a slight bit that is able to escape at those speeds. Oh, and all fluids can and do get compessed every day (some more than others). That's kind of how our CDFP builds the crazy high pressures it does (assuming it's really pretty much the same as the VW guys'). Fuel enters it's pumps cavity, fuel supply gets closed, fuel is compressed, path to fuel rail opens, fuel flies into the rail. All during one revolution of the cam-shaft. Fuel can compress slightly, but slightly is all we need when you consider how many times per minute this hapens. The other part of the story, is that the pressure regulator at the rail forces any extra fuel back in front of the CDFP (not back to the tank), so by your reasoning, upgrading the CDFP is just as worthless because the fuel rail can't hold any more.
What I think is happening, is since my pump is supplying fuel to the CDFP at a higher pressure/rate/volume, the CDFP cavity fills up faster, alowing it to pressurize inside the cavity before the CDFP starts to pressurize it. If you mechanically pressurize say 65psi of fuel, and then do the same with 100psiof fuel, you will absolutely see more fuel going through the latter system. You guys have a shop with a clean room, so test it. I'll send you my stock in-tank pump, and I'm sure you guys have better ones than that in your own inventory. Hook up one of your CDFPs with the stock in-tank pump feeding it. Log the CDFPs output pressure, rate, and volume. Then do the same with an in-tank pump that is better than the stocker. Are you afraid I might be right, and that people will have cheaper alternative for untuned, bolt-on cars? Man up and take the Walbro challenge, I bet you'll be suprized.
you made me giggle. silly silly.
fuel at 120-130bar is noice ;)
